ECOLITE – the new condensing units from BITZER
The compressor specialist BITZER is expanding its range of condensing units with a new series. The seven air-cooled models in the new ECOLITE series have been designed for low and medium temperature applications and come in an attractive housing.
The three LHL3E ECOLITE condensing units with one fan as well as the four LHL5E units with two fans open up a wide range of applications, from 1.5 kW to 5 kW in the low-temperature range and from 3.5 kW to 16 kW in the medium temperature refrigeration range. All seven models in the new series have been designed as a standard for both low and medium temperature applications and for a multitude of applications – for example, in cold stores, display counters and small shops.
Flexible and compact
Thanks to the mechanical VARISTEP capacity control, all ECOLITE condensing units offer smooth adjustment of the capacity in a range from 50 to 100 percent. In the LHL5E, the ECOLITE series offers optional capacity control from 10 to 100 percent. The condensing units have also been specially developed for low noise operation and have a robust and corrosion-resistant housing for outdoor use. Thanks to their compact construction, they can also be easily integrated even when space is limited.
Future-proof and sustainable
BITZER ECOLITE condensing units are easy to use, have control software developed by BITZER and work very reliably thanks to the well-known development and production work at BITZER. "Users benefit from the fact that all components are precisely matched to one another," said Stefan Dorn, Product Manager System Solutions at BITZER. "The entire series is Ecodesign-compliant and has been designed for use with common refrigerants. This also includes refrigerants with low global warming potential (GWP) such as HFO (hydrofluoroolefin) mixtures," said Dorn.
Intuitive and convenient
All components in the ECOLITE condensing units are easily accessible and the controller stands out due to its intuitive operability while enabling the use of the BITZER Electronics Service Tools (BEST). BEST ensures a user-friendly overview of the operating status and parameters and also offers support via a data logging function and the convenient setting of parameters.
